Hydraulic Trunk Problem
crafteee12
01-25-2009, 01:48 PM
My 92 RS has had issues with the wipers not always working. If I wiggled the white wire they would usually come on but as soon as I used my signal they stopped. So for the better part of 3 yrs I've driven without working wipers. Until a few weeks ago when my boyfriend of 7 yrs who happens to be a mechanic (so I hear) decides to hook up a switch and splice into the wire to the wipers & to the battery. Something like that, anyway it worked for a day or two until frying the wire. My problem is I opened the trunk using the release button it opened fine but will not latch, no light comes on either. Where do I begin to look for the problem? I assume its a short although I checked fuses with no luck. Sorry for my lack of knowledge. Need help
Morley
01-25-2009, 10:07 PM
Start by checking for power back at the hatch motor (I assume you have the electric pull down). If no power to it, you'll need a wiring diagram to trace the wire to its next stop going forward.
If there is power back there, you have a relay and switch that operate the pull down.
stetzz05
02-09-2009, 03:26 PM
if the lid releases then there is power to the pull down as they share a common circuit. my bet is the wiper-trunk latch problem is unrelated....the pull down on my 91 formula stopped working.. turned out was just a bad prong on the harness. undo the harnesss at the pull down motor and check it out. if its fine its likely the relay on the motor
