85 gmc jimmy v6 manual, cranks but won't start
bbullsj
01-23-2009, 02:17 PM
i ahve a 1985 gmc jimmy with a 2.8 liter v6 and a manual trans. it cranks over fine but won't fire. i checked for spark and it doesn't have any. the guy i bought it from said to me before i bought it that it had an issue with not starting sometimes but then other times it would start. i have multiple coil packs for it but they have tested good (one was a brand new one) what do i need to check and what could cause it not to have spark. i had a problem with my 89 cavalier that the crank sensor went bad and wouldn't let the car have spark but i was told that the jimmy doesn't have one. i would really appreciate any help on what to look for or test. thanks
MT-2500
01-23-2009, 02:56 PM
Ign module and dist pick up coil needs tested.
Is dist turning when cranking?
Battery voltgage to coil.
Where are you checking for spark?
bbullsj
07-12-2009, 04:08 PM
i was testing from the coil to the coil wire that goes to the distributor. i have 12.26 volts from power wire going to the coil. what do the 2 wires coming from the distributor do? what does the other wire (white wire) next to the power wire do?
bbullsj
07-15-2009, 08:14 PM
i started testing stuff after i bought a repair manual and i found that the ignition module was bad. i replaced that and it started right up. :)
MT-2500
07-16-2009, 08:26 AM
Thanks for posting back how it went.
Yes proper testing before throwing parts at it makes you healthy wealthy and wise.
Sure saves head aces and helps pocket book out.
