Blend Door Actuator Access 97 Bravada
nspbravada
01-10-2009, 06:33 PM
I need to access my blend door actuator motor. I've read the threads on the procedure but most refer to a 98. These posts say that the glove box can be hinged down. On my 97, the glove box compartment is welded (plastic) in place so I don't have access. Does anyone know if there is another way to get at the blend door motor on a 97 short of removing the entire dash?
I have a picture of the glove box but can't attach for some reason.
Thanks,
Scott
Thanks,
Scott
Chris Stewart
01-13-2009, 08:11 AM
The service manual says the instrument panel has to be removed. You can follow the vacuum hoses from the temperature knob to the blend door.
All help gratefully accepted.
