1998 Conti MAF readings
chuckneste
12-25-2008, 08:21 PM
What is the range for the MAF sensor.
chuckneste
12-28-2008, 11:15 AM
ok, I replaced the maf again and it reads at .5 at idle. I test drove the following cars and tested MAF at idle. All read about 10.
I replaced
TPS sensor
MAF Twice
DFPE Sensor
removed / cleaned EGR valev/ throttle body /tested /replaced with new gaskets
changed plugs / ran injector cleaner x2
dropped fuel tank. cleaned fuel pump assy ( which was very clean)
replaced fuel filter
tested for 25 lbs on the fuel rail / 30 with pedal floored
My 1998 Lincoln w/ 100 K seems to have a hesitation /jerk but 2 transmissions guy thought this could be engine related
1998 bmw z3
2003 chevy avalanche
2003 Honda oddysey
1999 Toyota camry
2007 Ford mustang.
after cleaning the oxygen sensor before the cat( I had p0171 and P0174 all gone now) , my long term fuel trims went from 24.9 to 15 and my short tems went from 32.8 to -6 to 16. My average MPG was 20.1 in Atlanta traffic which I think is good any I now have NO CODES. I have incomplete test ran on the car for the following using a scan tool.
EGR INC
CAT MON INC
OXYGEN MON INC/ Did read ok at one time
EVAP INC but the following were ok
misfire mon OK
fuel system OK
COMP Component OK
Would this indicate a PCM issue. Whee is it located???
