2004 3.5 Rodeo Will Not Start
CAF2004
12-18-2008, 10:00 AM
While driving my rodeo it shut off and would not start since. It cranks but does not start. after i let the key go it continues to crank. Had starter checked, and it was good. Was told it might be vehicle immobolizer. has any one had this problem?
Andie_J
12-18-2008, 03:01 PM
:confused: :confused: They are made to try to start even after you release the key. Have you checked your gas and filter? Are you getting a check engine light? If so get the code read. Andie:smile: :smile:
amigo-2k
12-18-2008, 05:20 PM
What about the starter relay?
Gizmo42
12-19-2008, 03:21 PM
That sounds like fuel pump, timing belt, or immobilizer on an alarm system to me.
None of the above should cause that. Bad ignition switch, or sticking starter maybe.
Possibly a bad ignition switch could cause both, but not sure.
Andie_J
12-19-2008, 10:38 PM
http://i441.photobucket.com/albums/qq132/ddjddj9/032.jpg
Andie_J
12-19-2008, 10:53 PM
:smile: :smile: Sorry for the size of the Picture, is it still under warrinty?:smile: :smile: Andie
FL 3.2L
12-20-2008, 09:24 AM
Hmm. Interesting.
Gizmo42
12-20-2008, 11:04 AM
Learn something new every day. First time I've heard of that.
rod2004
09-20-2010, 01:12 PM
That just happened to me too.
It turned out to be the fuel pump.
My fuse kept popping out and then I had to get out of the car to put in new fuse for another 10 miles or so.
