Applying brakes caused car to stall.
rnj
12-06-2008, 11:51 PM
I have a '97, 88. 84,???miles, and this just happened twice yesterday, and is the first time we have experienced this. Haven't driven car today. When I was coming to a stop, as i pushed the brake pedal, I heard a low sounding pop, and the car stalled, no lights on dash. but started right away. This cleared the time on the radio, but not the present stations. The second time was almost the same I was coming up to a turn, had the turn signal on, (cause I'm a cautious driver :evillol: ) pushed the brake pedal and i heard the pop again this time I saw 3??? dash lights on the lower left side flash for a split second then but car did not stall his time. I'm pretty sure one light was for anti lock breaks, and the one to or two to the right or lower, Any ideas????
maxwedge
12-07-2008, 09:09 AM
Check all your battery cables particularly and all the ground connections.
rnj
12-08-2008, 06:35 PM
TKS, It stalled again today and I checked the batt. cables. Pos. cable had corrosion, and dull contacts. Neg. look fine. Cleaned them up, and we will see. I will check the grounds also, tks. And where would I find those grounds?
rnj
12-28-2008, 05:08 PM
ok, any reason why my pos. batt. cable keeps comming loose?
maxwedge
12-28-2008, 08:21 PM
The bolt is corroded, the battery threads corroded all reduce the thread engagement is one posssibility, or the cable is positioned where it is being pulled down,
