94 lt1 misfiring
gorgepr
12-03-2008, 08:39 AM
here is the deal, I put a new ecm on my 94 T/A, the car misfires from 1000rpm until 3000 after that runs pretty good I already change spark plugs, wires, ignition coil, and I cleaned the distributor and the rotor, new fuel filter, cleaned out the injectors, has anybody had this problem before help will be really apreciated
btw the m...... f..... new ecm regulates the car at 110 mph and I remember the old one didn't
poormillionaire2
12-03-2008, 09:42 AM
Do you know what year car the new PCM came from? And why did you have to change it in the first place?
gorgepr
12-03-2008, 09:54 AM
the old one had problems with the tps, and it made the transmision get on overdrive almost every time, ie, I was crusing about 60 mph applying the trhottel just a little and the car applied overdrive by it self, and I just went to advance autoparts and ordered the pcm for a 1994 trans am with lt1 engine I belive it was p the vin code thet he asked me for
wrightz28
12-03-2008, 10:27 AM
Did you verify that the TPS was not the problem all along, sure sounds like it may have a dead spot in it
gorgepr
12-03-2008, 10:42 AM
yes I changed the tps and it did the same thing, when we scanned the tps reading was jumping from 64 to 90 something then I switch my ecm to my dad's car ( its also a 94 T/A) and it read the same thing on his car, i'm thinking that it could be the optispark or the cap and rotor, btw do you know what is the normal fuel pressure on this car?
wrightz28
12-04-2008, 11:21 AM
'bout 45psi
gorgepr
12-04-2008, 09:18 PM
thank you guys, but I put the old pcm back and it worked just fine, back in bussines
