Emergency break sensor not working?
rrussou812
11-20-2008, 02:09 AM
Hello,
I have an '02 Grand Cherokee and it seems like the emergency brake sensor isn't working. From what I can tell it seems like the brake itself IS working just the sensor indicating that brake is up...isn't.
Is there a fuse that needs to be replaced for this type of thing or something more?
Thanks in advance for the help.
Bob D.
11-20-2008, 11:40 AM
Are you talking about the red BRAKE light in the instrument cluster?
If so it may be a bulb, the light should be visible when you turn the key to START..Self test ...
Don't know about a fuse - a bad fuse would cause a lot of other things to quit also.
rrussou812
11-20-2008, 04:24 PM
Yes, it comes on when I start up but when the parking brake is pulled up it doesn't.
Bob D.
11-20-2008, 08:28 PM
Then it sounds like the parking brake switch.
