1992 g30 heater motor problem
jolear
11-17-2008, 06:20 PM
My heater motor is not working. I did the following. Checked for power at the motor and got 12.8 volts. So I figured the motor was bad took the motor out and decided to just check it. I hooked it up to my battery charger and it worked. I reinstalled it, no good again checked voltage and had 12.8 volts. Any ideas would be appreciated.
John
brcidd
11-17-2008, 08:07 PM
Is that voltage you measured WITH the blower motor plugged in? or with it unplugged?- makes a big difference- you may have bad contactsin relay that can show voltage, but not pull the amps needed to run a blower motor- if you measure o volts with the blower plugged in, then you have your answer.
