89Civic1.5DX Hatch - Engine coolant Drain Plug
Moe Arif
11-13-2008, 08:20 AM
The engine coolant leaks through the drain plug, no matter how tight I shut it close. So need to change it. Problem is, after it is opened / unscrewed, it holds itself inside the collant exit chamber.
How do I take it out to replace it. Once it (the old plug) is out, what's the trick to put the new one in - May be a stupid question but I have never done this on any car.
FrodoGT
11-13-2008, 01:15 PM
Use teflon tape and youll be good to go.
Moe Arif
11-13-2008, 01:44 PM
Thanks FrodoGT, I'm gonna try it in a week's time. Any idea for the replacement.
Christ
11-15-2008, 12:05 AM
I'm pretty sure they're pinch fitted... you need a long pair of needle nose pliers to squeeze the end back together while pulling it out.
My wife's GP had this same POS thing on it.. I promply ripped it out and replaced it with a wing-bolt of the same thread pitch/size... wrapped, of course, in PTFE tape.
