Ground
chrisanthony
10-28-2008, 03:15 PM
Hi
I got a 96 escort lx. All my speakers seem to be crackling and the sound seem to be switching over to the right side at random times. I tested out and installed new speakers also. Could it be a ground problem from the reciever. The only ground i see is within the power connector going into the receiver.
Thanks for the help
Davescort97
10-30-2008, 12:12 AM
Yes, it is probably a ground problem. Try running a ground wire between the case of the receiver and the car. The reason I'm saying this is that I put in an aftermarket receiver and had it all together. The speakers made a crackling sound and and not much volume. I grounded the frame of the receiver to the ground of the car (frame). Everything cleared right up. If you don't have a receiver with a metal frame, run a ground directly to the battery.
chrisanthony
10-30-2008, 09:31 AM
Thanks davescort97 I'll try that this weekend.
chrisanthony
10-30-2008, 09:54 AM
How large should the groud wire be?
tripletdaddy
10-31-2008, 02:12 AM
18 or 20 gauge or whatever gauge the power line to the radio is. You should be able to find an already existing wire to ground screw under/inside the dash that you can use or create your own on any of the major metal inside the dash.
