Engine swap
300GTkid
10-27-2008, 05:00 PM
I have a bad motor and i was wondering could i use the motors from other years than my car, to use as a direct swap.I'm looking for another V6 non-turbo DOHC 24 Valve. Like a 1992,93,94,95,96,97,98,99 engine same car.
My car Information
1991 Mitsubishi 3000GT SL 3.0L DOHC V6 24 Valve
My car Information
Stealthee
10-27-2008, 05:16 PM
Basically yes. There will be some parts that will have to be swapped from your old engine to the new engine if you anything 93+ though.
300GTkid
10-27-2008, 06:26 PM
Can you please list the parts that i need to swap from previous engine thanks
Stealthee
10-27-2008, 06:46 PM
It will depend.
93+ has a different cam and crank angle sensor set up. You would have to swap your CAS onto the rear head if you get 93+
Other than that if it is 94+ and has an EGR you will have to swap on your intake manifold and exhaust manifolds.
If its 94+ you will need to swap in your thermostat housing IIRC because the first gens have there sensors in the rad where the 94+ have them in the housing.
There could be other things I am missing but basically whatever is different will need swapped.
300GTkid
10-28-2008, 12:20 PM
It will depend.
If i was to buy the Same year,exact engine imported from Japan would that be diffcult or the same as an American Version
