What is sand? or sandwich? Help
Tunero
03-17-2003, 11:17 AM
Hello, i need to know whot is Sand, or Sandwich, tha i see is used in the models, where can i buy it?
freakray
03-17-2003, 11:20 AM
:confused:
Sand is the stuff you see on the beach, a snadwich is something you eat.
What exactly are you referring to?
Do you mean flocking which is used to simulate carpet?
:confused:
Tunero
03-17-2003, 11:24 AM
Ayala
03-17-2003, 11:29 AM
those are styrene strips. the pix shows how to create an extension for the fenders using styrene and putty.
--------------------------->:confused:
Geez
03-17-2003, 11:33 AM
http://www.automotiveforums.com/vbulletin/showthread.php?postid=838890&t=2630#post838890 should help...
Here's a reiteration of what I posted there...
"Ahhhhhhhhhhh, I think I've got you now. By "sand and sand and sand" he meant using "sandpaper", which I'm sure you must have seen before. It's basically a paper with a "grit" like little stones, or grains of sand. To sand a surface means to rub the surface with the grit paper, by which you take off some material and smooth the surface. Generally, it's a long, careful, and tedious process. Hence, he said, "sand and sand and sand" meaning it took a long time to smoothen out."
Tunero
03-17-2003, 11:34 AM
and where can i buy?
Geez
03-17-2003, 11:39 AM
Any hardware store should have coarse sandpaper. You may have to go to a local hobby shop for fine or ultrafine paper.
Sand paper is rated on a bit of a confusing basis. It's based on "grit" which is somewhat equivalent to stones per square inch. A 320 grit paper will be very rough, while a 2000 grit paper will be very fine. Before painting, you should have smoothened the surface with about a 1000 to 2000 grit paper. However, most of the time you will only find up to 600 grit paper at a hardware store. If you use this, it will leave quite a few scratches on the surface, that will be visible after painting.
Another consideration is that sanding is usually done "wet". Normally you have to buy sand paper that specifically says "wet/dry". You then get the paper wet, and let it soak up water into the paper. This way, it captures all the sanded bits, and generally gives a much smoother surface.
Tunero
03-17-2003, 11:44 AM
But I want to use it to make extensions, I think that it is not sandpaper
Geez
03-17-2003, 11:48 AM
No, the extensions are made out of "styrene sheet", which you should be able to buy at your local hobby shop. It's basically just a sheet (or strips) of plastic. You then cut them to your desired length and shape, and glue them to the car as the extensions. Then put putty over everything, as the extensions won't look perfect yet. Then comes the sanding with sandpaper to make everything nice and smooth. Then primer and paint, and you're off to the races.
Geez
03-17-2003, 11:51 AM
this...
VVVVV Strips of styrene sheet, cut to desired shape and size
http://files.automotiveforums.com/uploads/6033557.jpg
VVVVV Styrene sheet glued to the body, but some large gaps need filling, and full profile of the flare isn't perfect yet.
http://files.automotiveforums.com/uploads/6759095.jpg
VVVVV Putty added to the flare. Makes the surface look not smooth.
http://files.automotiveforums.com/uploads/75507530.jpg
Next comes sanding, which brings the surface to a nice smooth finish, ready for paint.
this...
Tunero
03-18-2003, 06:22 AM
i see...
