95 v6 camaro wont start, silent
SOME GUY
10-22-2008, 11:46 PM
ok i have a 95 v6 camaro that when i try to start it, it does nothing at all completlly silent. the only noise i hear is after i let go of the key and leave it in the on possition, it sounds like the plug trying to spark or just my ignition lock locking, but im not sure im no machanic, and its very quiet can barely hear it, i have to hold my keys so they dont make noise as i turn them, not to worried bout that thou.
anyways i know its not my resistor in my key or lock they are both brand new cause they were previouse probs. also not my battery new as well along with the posts. and all the battery cables look good but a couple of ground connectors have a little green and white corrosion on them that could use some cleaning.
also all my power stuff works fine (windows, locks, lights, radio). all the lights light up and go out like normal except for my security and check engine light. the security light keeps on flashing and the check light just stays on constantly. i tried to keep my key in the on possition for like 5 or 10 min to let the igniton lock read the resistor on the key just in case but nothing. and before i went to work it started just fine as always but after work it was completly silent didnt even try to start. this happened tonight so its chilling at work. also for like a week or two maybe longer when it idles (automatic tranny) it almost feels like it wants to stall kind of like it loses power or torque or shitty spark
tomorrow when i go to work im going to try to look at my spark plugs and wires but if you can leave a thought, also keep in mind that im cursed and anything that can happen will happen it seems like
any help would help THANKS
Genopsyde
10-23-2008, 02:36 AM
if you security light is flashing then your problem lies within that system, whether you already replaced it or not.
SOME GUY
10-23-2008, 02:29 PM
alright that means it might start up when it wants to right?? like before when i had that prob. also have u heard anything like the security will turn on in da cold and wont start cause it was pretty cold last night and its da first time iv had it in da cold??
