2001 Alero
buddyman54
10-19-2008, 09:04 PM
I Have A 2001 Olds Alero I Replaced The Fuel pump The Car RAN FOR A FEW DAYS THEN IT STOPPED . IT STARTS IF YOU SPRAY FUEL IN THROTTLE BODY
Iflylow
10-23-2008, 10:17 PM
Can you hear the new fuel pump run when you turn the key to the ON position (not start)?
You could have been given a bad pump, it's happened before.
The pump wiring could have a short or bad connection, that's not uncommon either.
The fuel filter may be plugged, unless you changed it at the same time you changed the pump.
Schrade
10-27-2008, 10:42 AM
I'd put the old fuel pump back in.
