HELP!! car won't stop overheating
dirtdriver11
10-13-2008, 09:41 PM
I got a 98 cavalier with a 2.2l 5 speed. I replaced a gasket on one of the radiator lines, and now all it does it overheats and spills antifreeze out of the coolant cap and the cooling fan does not come on. I tried the bleed screw on the heater hose, is there another one, where is it at? I seen on one post that there is one on the thermostat housing, but that was on a 96, is that the same for 98? Also, since doing this the low coolant level light is on on the dash but the tank is full of coolant.
Thanks
Chris
Thanks
Chris
Schrade
10-15-2008, 08:37 PM
A gasket on the radiator line? Not sure what that is... Was there a cooling problem before?
Has it been flushed? How is the heat (to check flow through the heater core)?
Jason/RKBA
10-15-2008, 11:38 PM
Replace the overflow cap and the T-stat then let us know how it's doing.
dirtdriver11
10-16-2008, 07:20 PM
working fine now, I didn't get all the air out of the system.
