my engine light came on!!
sahilp
10-02-2008, 01:47 AM
after my engine light came on my 1999 jetta. i took it for a scan for $90 dollar!!! and now they found out a P1136 code and i dont really know what that means? well is it a big of a issue?:banghead:
chasonique
11-12-2008, 03:32 PM
:biggrin: The P1136 code, that means that the Long Term Fuel Trim Add. Fuel B1 System is Too Lean. okay try to check for any vacuum leaks around the airbox, turbo, vacuum lines and intake gasket(s). You may also want to check fuel pressure. And just so you know jettas have a infamous problem with the mass air flow sensors. MUST TAKE IT too a volkswagen dealer. Hope everything is okay...
veedubmechanic
11-16-2008, 08:25 AM
what engine ?
