2004 Jeep Liberty 4x4
bjwc
09-30-2008, 09:48 PM
When I accelerate the jeep pulls to the right and when I let off the gas it pulls to the left. Anyone else have this problem. Or you mechanics out there have any ideas. Thanks in advance...
gravelagitator
10-07-2008, 06:46 PM
Ok, since no one else will answer I will give it a try. I assume your wheel alignment is good in the first place. It pulls to the right under all acceleration conditions? The only reason I can see that it will pull left after you get off the throttle is you turning the wheel left to go straight. The pulling right could be:
Alignment, Suspension problem, or drivetrain slippage. That's a just a guess on my part.
bjwc
10-12-2008, 08:07 PM
Had the jeep lined up and the mechanic said it was not out of alignment. We checked some more and found a rubber bushing at the rear end housing on the lower control arm was bad. Replaced it and drives like new.
gravelagitator
10-13-2008, 05:23 AM
Cool, glad you found out what was causing the problem. :tongue:
