dying VR-4
701-3000GT
09-30-2008, 06:51 PM
soooo....ive been thinking i have this little spark blowout issue from higher boost. so i turn my boost down and wala
then as i was driving yesterday...my intercooler,battery and e-break light come on. they were all somewhat dim though, not the actual warning lights.
then today as i was coming home from arby's (the single best fast food joint), my car decides it doesnt like me much anymore
-the previous lights turned off and now the anti-lock and srs lights grace my cluster.
-my car decides when it wants to accelerate (if not slow down), regardless of how hard my foot is pressing on the pedal. not that it will go without giving it gas, but when given gas it holds at the same rpm as when the gas is pressed
-it studders (not spark plug/slight missfire studder) in all spectrums of the rpms
- whenever my blinker is on...my speedo needle and tach needly bounce up and down in sequence with my blinker. the speedometer goes from below 0mph- around 30mph, bouncing back and forth..regardless of speed.
-idle rpms are all over the place (not an IAC issue)
-finally as i lurch into my garage, i stop the car at idle to let it cool down, and it idles up, then idles down quickly, trying to keep itself alive around 300rpms-500rpms then just gives up and dies within around 5 seconds of letting sit.
my headlights still shine bright, and when im driving my EBC says my voltage is just fine.
im thinking the problem is electrical, but i just dont know anymore...:banghead: :disappoin
i appreciate any help.
AutostradaVR4
09-30-2008, 07:09 PM
psrt of your problem sounds like it might be the MAF...but i dont know why that would cause random warning lights.
An easy place to start anyways. Other than that, possibly ECU? but i dont know why that would throw an SRS or ABS light.
I;m sure others will have more insight.
701-3000GT
09-30-2008, 07:14 PM
the MAF would make sense, but my car isnt throwing the actual check engine light and thats normally the case from my experience. i could be wrong though
TorchedStealth
09-30-2008, 09:16 PM
If you want we could swap it for the stealth's MAF like we did on your SOHC and see if anything gets better. We will have to try that tomorrow or sometime soon! Right as I kind of get my car running yours craps out:mad:
701-3000GT
09-30-2008, 11:20 PM
hahaha yeah we could, but the stealths gonna have to come to my place
im not trusting the verfer to make it to your house :disappoin
701-3000GT
10-01-2008, 05:08 PM
from what ive been reading sounds like it could be alternator issues
anybody have any input?
TorchedStealth
10-02-2008, 02:47 PM
Alternator is a possibility but I would think that your headlights would get dim when the RPM's dropped since that is generally a telltale sign of a bad alernator
701-3000GT
10-02-2008, 04:59 PM
yep....bad alternator
she lives again tomorrow:D
TorchedStealth
10-03-2008, 11:55 AM
She SHOULD be living all the way down to Sabin so you can break 12's, but NO Sid thinks the good choice would be to stay home and save money!
I has a kwestion.....WHEN DO WE EVER MAKE GOOD CHOICES????!!!!
Ha Im just giving you crap, maybe you can bring it down next time
Polygon
10-03-2008, 06:10 PM
Mine didn't throw a light when it died.
