roadmaster heating problem
scottdombeck
09-28-2008, 05:29 PM
I,ve read previous threads about heat issues with roadmasters but I'm still getting no heat. Our 1992 roadmaster 5.7 has 86,000 miles on it. A/c worked all summer but now with heat needed where getting nothing. I replaced the thermostat twice (failsafe first time,then 195 degree the second) Temp gage still rises above 220--will not steady at 195 ?? Flushed out system three times--clear water with no sludge. Took off the heater core cover --core is hot with no leaks.Core is getting hot water and all the vent doors work properly,also replaced heater control valve ,still no heat. Elecronic heat/ac controls seem to be stuck on a/c-- I select 90 degrees on heat/ac controls with the economy button select as well and recieve outside air with no heat,also when I press "auto" temp selection the a/c kicks on and blows a/c cold air. What I'm trying to explain is that I believe the a/c /heat controls are not swithing back and forth from cold to hot like its stuck on air condition mode.Whatever temperature I set the controls at ,I still get A/c cold air .Any suggestions??? I,ve tried all the ideas presented in this forum,I believe? Maybe I,ve missed somthing. Water pump??
thanks
thanks
scottdombeck
10-07-2008, 08:09 AM
I have seemed to have fixed the fluctuating temperature gage by replacing the coolant temperature sensors (TWO)-top of block and driver side of block-there are slightly different so examine carefully when replacing.
Engine is also running better,replace plugs wires(one wire was rubbing against control arm and grounding out),distrubutor cap/rotor,and found a small vaccum leak near the carb.
Heat problem still exists. A/C will not disengage on temperature setting of any choice,otherthan economy(outside air).Is their a a/c relay ,and where is the other fuse box,checked all fuses near drivers door,but cannot find addition fuse box under hood or dash????
Any help would be appreciated.
thanks
scott
thanks
scott
