2004 gtp front end growling noise
cragarjames
09-24-2008, 05:18 PM
Hello My a 2004 gtp 11800. klix recently started making a growling noise only when i turn right , thought it to be barining so replaced hub baring etc and no change, it's getting worse now it growels kinda grinds going straight also can here it get a little louder when i break and gets alot worse when you turn right and gose completly away when i turn left any clues where to start befor i start poring monny into it , like the 240$ barring that was not needed.lol.
GTP Dad
09-24-2008, 07:17 PM
Welcome to AF!
It is possible that the bearing on the other side is bad. They usually don't go bad this fast but anything is possible. Since you did say if the problem occurs when braking check the brakes to insure that there aren't any problems with the pads or a loose caliper. Also check the left side to see if there are problems there with the brakes.
