Help Speed Sensor
gparty33
09-19-2008, 02:35 PM
I have 98 gs computer code is speed sensor a replaced both sensors and instrument clust cause odometer and speed did not work still does not work what @#$% can i do someone help please?
david-b
09-19-2008, 02:42 PM
Can you please take a minute to rewrite this so it's legible, using proper grammar and punctuation? You're not going to get help if we can't understand what you're saying. Thanks
Actually I'll do it... leading by example...
I have 98 GS. Check Engine Light code is for the speed sensor. I replaced both sensors and the instrument cluster because the odometer and speed did not work. It still does not work what can i do? Someone help please.
Both sensors being what? Did you check the wires for shorts or cuts?
SilvrEclipse
09-19-2008, 02:54 PM
I only know of one speed sensor. Is this a 5spd or auto? I would check to see if your getting power to your speed sensor first.
gparty33
09-23-2008, 02:07 PM
the code is speed sensor a malfunction p0500 replaced the out speed sensor and the in speed sensor replaced instrument cluster my car 1998 eclipse gs 2.0 auto tested the wires they have good ohm ( with in there range ) my speedometer don't work and odometer what else could i do????
david-b
09-23-2008, 03:53 PM
Translated To:
The code is speed sensor a malfunction, p0500. Replaced the out speed sensor and the in speed sensor. Replaced instrument cluster also. My car is a 1998 Eclipse GS 2.0 auto. Tested the wires and they have good ohm ( with in their range ). My speedometer and odometer does not work. What else could I do????
I'm not too familiar with the auto trannys, but what 2 sensors? Never heard of "in and out" speed sensors.
Check your fuses and make sure everything is good. Do your temp and fuel gauges work fine? Are the wires coming off the ECU good? I'll try to find the pinout and show you which ones to check.
gparty33
09-25-2008, 10:18 AM
all the gages work but my speed and odometer that would be nice if i new how to check the ecu please let me know how??????????????
LandoAWD
09-25-2008, 11:13 AM
Take it to AutoZone or Advance to pull the codes.
Stop by borders on the way back snag a fucking book on the English language, too. :headshake
david-b
http://www.2gnt.com/index.php?d=1998%20ECU
Here's for the 98 ECU. Check the wires coming off the ecu. I would strip just a little bit off of them and test to see if there's current flowing.
Feels like something is missing in this whole endeavor to find the problem.
LandoAWD
09-25-2008, 11:15 AM
Hah! Pwnt by not scrolling down far enough. Missed the more recent post.
Well, sentence 2 still applies...
