Windshield Wipers
Celtik
09-17-2008, 01:08 PM
Alright, I have posted about this before but I have still yet to fix it. Well, I realized that my wipers must have a short or something of the sort somewhere. They work if I lift the hood, and move the wires around ( i guess from the motor). They work for a little bit and then they sometimes stop working while I am driving. I can hear the wipers trying to work, but they do not move unless I move the wires around. Any suggestions on what I would need to buy in order to get this fixed?
TomB985
09-17-2008, 02:03 PM
If you can hear them trying to work, but they aren't moving, I'm willing to bet it's the wiper motor. Can get them aftermarket for around $50
old_master
09-17-2008, 04:35 PM
Most likely this is what you need: http://www.partsamerica.com/productdetail.aspx?MfrCode=DOR&MfrPartNumber=88136&PartType=2040&PTSet=A The solder joints on the printed circuit board break and cause the motor to operate intermittently. Available at most auto parts stores for under $30.
Celtik
09-17-2008, 10:43 PM
OK, so I just buy that wiper pulse board and then it should be fairly simple to install?
old_master
09-18-2008, 07:10 PM
One electrical connector, and maybe 3 screws...done!
mike2004tct
09-18-2008, 08:44 PM
And some goop (RTV) to keep it water tight.
Celtik
09-18-2008, 09:06 PM
Could you link me to these materials, like to show exactly what I will need?
old_master
09-18-2008, 09:37 PM
A small bead around the edges of the circuit board will help seal the board from moisture. http://www.partsamerica.com/productdetail.aspx?MfrCode=PTX&MfrPartNumber=80022&CategoryCode=2132
Celtik
09-19-2008, 09:30 AM
What about the electrical connector?
MT-2500
09-19-2008, 09:47 AM
The module is unplug wiring to it and remove cover and pull out old module and stick new one in and plug in wiring plug and go.
Celtik
09-25-2008, 10:11 AM
Alright, I got the part so I am going to try to get it working.
MT-2500
09-25-2008, 10:24 AM
After you get it installed.
That should do the job.
Good Luck
And let us know how it goes.
Good Luck
