98 Blazer 4wd Front Actuator / Cable
Skymac
09-14-2008, 03:18 PM
Just pulled my battery tray off and wanted to check the actuator. I took the vaccuum line off pressed in the actuator and it held (no leaks) so I assume its still good? MY real question is, does any one know how much travel that cable should have, how far should I be able to manually pull it to know that its not sticking, etc? I really want to get my 4wd working for sound of mind but its just being pesky....
Skymac
09-14-2008, 04:10 PM
Well it started to rain here so I buttoned everything back up, at the Actuator i had about a 1/4 of travel outward on the cable and when I pulled on it i got a click when I was at the end of the travel. I suppose I could have checked to see if the Right tire was engaged but no jack it has ran off somewhere, anywho, any advice will be greatly taken.
MT-2500
09-15-2008, 10:00 AM
Yes you need to check for front axle engagement.
http://www.automotiveforums.com/vbulletin/showthread.php?t=572914
