AIR DRIED BEEF DOG FOOD
88 crx dx temp gauge
vothman30
09-14-2008, 12:52 AM
I have a 88 crx dx the temp gauge will jump to Hot and then it will go normal for a while and than jump back upto hot. I have replaced the the thermosensor that didnt work and cannot find the temp gauge sending unit and pic would be help full.
THanks V
FrodoGT
09-14-2008, 01:30 AM
The temp gauge sending unit is under the distributor. It is a one wire plug and pretty easy to spot. Also the jumping up and down is either from low coolant causing a hot spot that cycles through your system, or more likely a bad ground in the engine compartment.
Christ
09-14-2008, 10:08 PM
I'm thinking it might also be a thermostat... if it keeps closed, then opens and closes again... that might allow the temps to rise, then fall quickly like normal, but then if it closes again, temps go up again... see what I mean?
Look under your distributor on the head... there are two "things" there... one is two wires, the other is one wire... the one wire one is the one you want.
vothman30
09-15-2008, 09:27 PM
:banghead: I have replaced the thermostat and now it is still doing it. Sometime if i thumb the dash it will goto normal than right back to hot? Is there a certain why that the thermostat needs to go in i have read something on this forum that it could be affect by this?
Christ
09-16-2008, 08:01 AM
Um.. well, yeah, and if you put it in backwards, it won't open.
