2001 Neon clicks but won't start unless I,
MrVegas
09-11-2008, 03:31 PM
...disconnect a terminal, reconnect it then it starts right up. Of course my clock ain't the same but it starts. Any ideas?
-MrVegas
angus10
09-11-2008, 03:50 PM
It is possible that the battery post going into the battery is not making contact inside the battery. Does it seem loose? If not check the other end of the cables. Where the ground connects to (on block most likely)and where the pos. connects to.(on starter most likely)
CoolasIce
09-11-2008, 04:04 PM
Good idea. I had a battery once that had this problem.
MrVegas
09-11-2008, 04:12 PM
No it doesn't appear loose at all. I took the battery in when this first happened and it was fully charged. No corrosion on the terminals at all. You think it might be cables?
I hope it's not a starter problem. I'm not ready with 300 bucks to fix it.
-MrVegas
angus10
09-11-2008, 05:24 PM
No not the cables, but check the other ends of the cables where they are mounted like I said. If you have done that already, I'd say remove the starter and Autozone or wherever can check that too.
angus10
09-11-2008, 05:28 PM
And BTW! You do have a starter relay. Get a manual and you can locate and check it. Or someone here might know exactly where it is.
angus10
09-11-2008, 05:31 PM
There is also a TSB from Dodge about something do with the starter, look into that. You might get it fixed for free. http://auto-recalls.justia.com/content/00V416000-DODGE-NEON-RT-2001.html
