2003 S10 Wont Start, Dies When Gas Is Let Off
sj3324
09-03-2008, 09:50 PM
2003
CHEVROLET
S10
2.2L (4 CYLINDER)
80,000 miles
I was driving my 2003 S10, and shut it off to go to class. When I went to start it up to go home, it wouldn't start. I had a friend jump me, and it started right up, and idled just fine. I took off and all of the dash lights began flashing, my radio went off, and the guages started jumping around. When I let off the gas to shift into 2nd (manual trans.) the truck (http://autoforums.carjunky.com/Automotive_Repair_C1/Electrical_and_Wiring_F6/gforum.cgi?post=33994;t=search_engine#) died. I had this problem over and over.
This happened also back in January and I took my alternator to Auto (http://autoforums.carjunky.com/Automotive_Repair_C1/Electrical_and_Wiring_F6/gforum.cgi?post=33994;t=search_engine#) Zone and it tested bad, so I got a new one and it started right up. I had a couple problems off and on after that, but I hadn't had any for a couple months and now it is messing up again. The alternator was a pain to get off, so I thought I would see if there could be any other causes before I went to check that again. Any suggestions??
Thanks!!!!
CHEVROLET
S10
2.2L (4 CYLINDER)
80,000 miles
Thanks!!!!
19bigt51
09-04-2008, 06:05 PM
have you pulled any engine codes? If so what are they? Is there much corrosion around the battery terminals? Your truck is only a few years old, but check the battery cables over good, making sure that they make a good connection at the battery and where they terminate. How old is the battery? Have it tested too, just to make sure it is capable.
sj3324
09-04-2008, 07:25 PM
I got it all figured out. I had a bad connection to the battery. I forgot all about checking that from the beginning because I was just afraid it was the alternator, like last time when it tested bad. After I tightened the cables it started right up, went to Wal-Mart and had them test the battery, starter, and alternator and they all tested good!! YAY!!
THANKS!!!!!!
THANKS!!!!!!
