95 neon engne swap
speedman12
08-30-2008, 11:58 AM
i have a 95 neon, iam thinking about putting a different engine in, what would be a good one to get and what all would i need.
das2123
08-31-2008, 07:18 PM
From the FAQ's up top....
Q: What other engines can swap into the 1st gen neon?
A: A 2.4 engine from a 95 to 00 Stratus, 96-00 Caravan, 01 & up PT Cruiser. The SRT-4 engine will swap in also. These are not direct bolt-ins and will require some modification, but they are very doable.
Q: What do I need to get the SRT-4 engine in my 1st gen?
A: You will need the engine, a 2.4 side motor mount adapter, wiring harness, and a NEW PCM that has not seen sentry, unless you are ready to swap the sentry stuff over also. You can eliminate the PCM and run the engine using Megasquirt. Don’t know what that is, Google it!
Automotive Network, Inc., Copyright ©2023
