Install From scratch an aftermarket Tach
Jani-mani
08-28-2008, 04:47 PM
Hi,
i just bought an aftermarket tach. i want to install it on my 97 corolla, but have no idea where to begin. if anyone can give me some detailed instruction i'd appreciate it. its 4 cyl, sd 1.6L model. the tach itself has five wires, black(thick), Green(thick), Red (thick), Red(thin) and Black (thin). the tach also has a switch in the back to adjust for 4, 6 and 8 cyl cars. let me know if you need more info.
thanks.
regards,
Jani
jdmccright
08-29-2008, 10:18 AM
More info on the tach is needed. Brand? Model? It should have come with installation instructions, but if you got it second-hand, company websites usually have online copies as well.
I'm guessing some wires (thinner?) are for powering the meter (illumination and signal processing) and the other (thicker?) wires are for attaching/splicing to the ignition system to sense the spark pulses from a single ignition coil. If the '97 has coil-on-plugs, then this meter won't work.
Jani-mani
08-30-2008, 01:47 PM
hi,
I don't know the brand or model since i bought from my country this summer, and the instructions are in chinese. although it does mention info on 3 of the 5 wires. for Red it says (ACC), Black (-) Ground, Green (signal), White (B+) this wire i don't have. also the spark plugs don't have soil on top of them.
thanks,
jdmccright
08-30-2008, 02:46 PM
Take a look at the following web page. It isn't your exact setup, but it is very similar.
http://www.offroaders.com/tech/Autogage-Tachometer.htm
The red (ACC) wire connects to a key-on circuit for power, the black (ground) goes through the firewall to a good solid body ground, and the green connects to the negative pole of your ignition coil's primary winding. I'm guessing the white (B+) wire is for illumination of the gauge face and/or redline light. You mentioned a fifth wire before but couldn't tell you what it's for.
All I can suggest is to continue searching for install instructions for any A/M tach and check them out to see if they are similar to yours. Good luck!
Jani-mani
08-30-2008, 08:15 PM
Hi
the white wire i don't have, it was just mentioned in the instructions. also what is the firewall and where is it. and where can i find the ignition coil?
Thanks,
Jani-mani
09-10-2008, 08:13 AM
Hi again.
Thanks for the help, i got the tachometer to work. Thanks again, really appreciate it.
Regards,
Jani
