Need help! - S10 front end bushings?
AlphaBitch
08-25-2008, 01:07 PM
1 - got a flat
2- got new tires
3- needed an alignment
dude wouldn't / couldn't do my alignment because my bushings are bad and he doesn't have the special 'offset wrench' needed to do it???
so...
1 - WHAT the heck wrench do i need to buy
2 - WHERE the heck do i buy it
3 - what bushings do i need to order???
people at the stupid chevy dealer / parts store are being NO help!
i vaguely remember having to do this on my '99 blazer... so i know it can be done... so...
someone? anyone? out there know how / where / what do do from here??? please email me ASAP
THANK YOU!!!!
yahooIM - fumiko4lrk
msnIM - schh3fh
2- got new tires
so...
THANK YOU!!!!
msnIM - schh3fh
inafogg
08-25-2008, 02:12 PM
hello alpha,not sure of which model/year & i'm guessing on which bushings are worn out but..
if its the control arm bush there is a special tool but dont think you have to use it.basicly remove arm press/drive old bush out (i use an air hammer)& then grease the new bush & press it in using a large socket the same size
there are other bushings on your car & i'm guessing which ones your talking about.good luck
AlphaBitch
08-25-2008, 02:28 PM
sorry... missing info
POS Chevy S10 2000
front driver side tire is 6.5 degrees off, passenger tire is 1.0 degrees off
apparently it needs a special wrench... because chevy likes to make things as fucking hard as possible to fix....
any ideas???????? i'm ready to scream!
POS Chevy S10 2000
MT-2500
08-25-2008, 04:36 PM
As said you do not need special wrench for installing bushings.
Just replace the bushings and what all else is worn out and look for another alignment shop.
If a special wrench is required to realign front end let the alignment shop buy it or take care of it.
Good Luck
MT
Good Luck
MT
