2000 ford explorer DRL's not turning off
gary m
08-25-2008, 06:32 AM
My daytime running lights will not turn off. Disconnecting the battery cable is the only way. Anybody have any suggestions to the problem?
shorod
08-25-2008, 06:40 AM
Do you want to keep them working, or would you be happy with them just being disconnected?
I did a quick search on the forum and it sounds like it's been pretty common for Explorers to have issues with the Daytime Running Lights. However I didn't see anyone who's really fixed them other than replacing the DRL module. I'm not sure what that costs.
You will probably need to find a wiring diagram to properly diagnose the DRLs.
-Rod
gary m
08-25-2008, 10:01 AM
I need the lights to function as per local laws. I will check the module. Do you know where it is located on the vehicle and how it might be labelled?
Thanks for the reply.
fordtech99
08-29-2008, 11:54 AM
should be located in driver fender well. It will definately be the module. likely aroud $100.00
