Engine Line On
rell2tru
08-21-2008, 08:17 AM
Okay, I'm back! Anyway, let me break it down for ya'll:
Fuel pump done three months ago...one month later, engine light comes on. Turns out it's a smoke leak from my fuel tank, but the engine light turned off once testing was done.
Now as of yesterday (two months later), I turn my car on and all of a sudden it's back on. Same code, so it's another smoke leak. The people I took it to did a crappy job and I'm not going to them no more.
Any suggestions? Also note that I do need an EGR valve, but i wouldn't think that wouldn't have to do with anything. But any help is appreciated. Thanks!
maxwedge
08-21-2008, 08:50 AM
What is the code?
rell2tru
08-21-2008, 09:24 PM
440 code: It's saying something about the EVAP system. And NO my gas cap is not broken or loose.
maxwedge
08-22-2008, 06:51 AM
Code refers to a leak in the evap system which can be anywhere, starting with a bad gas cap seal, if the fault is not a visible rust thru or break in one of the components, then usually a smoke machine is required to find it.
rell2tru
08-23-2008, 10:03 AM
I had a smoke machine used on my car before and they found a smoke leak coming from my fuel tank. Should I just have the tank dropped and see what the problem is?
Scrapper
08-23-2008, 10:38 AM
that should have multiport fuel inj right? well have someone with a guage to check psi. on pump before you go drop tank.
