2002 Radiator petcock
longrider1951
08-17-2008, 11:58 AM
Where the heck is the drain petcock located on the radiator? 2002 Chrysler Town & Country EX
Thanks for any replies.
Glenn
webbch
08-17-2008, 05:56 PM
Not sure on the 2002, but given the tendency of it to be frozen up when you go to use it, and a royal PITA if you break it off, I always just disconnect the lower radiator hose. Drains faster too.
Chad
longrider1951
08-17-2008, 06:55 PM
Thanks for the reply. I'm pretty sure I found it on the left (drivers side) of the radiator. Problem is it only seems to turn 90 degrees and when I turn it nothing drains. Any other input will be appreciated.
Thanks, Glenn
Bear
08-17-2008, 07:01 PM
Petcock is on lower left, drivers side and it is a PITA to remove, in fact you usually destroy the rubber "O" ring and have to replace that. I second the disconnect lower radiator hose to drain the cooling system.
