2000 GMC Jimmy just won't start....
Hiway
08-13-2008, 07:37 PM
I have a 2000 Jimmy and it just won't start. When I turn the key, it won't crank, just shows a SERVICE ENGINE SOON LIGHT. I had this problem before and the problem was a bad starter relay. I've replaced the relay, again, but it didn't solve the problem. The vehicle started up fine and ran great all day, until this afternoon when I tried to restart it. Battery is good, changed the plugs this past fall, starter was replaced a year ago and I checked all the fuses related to IGN, all are ok. I just don't know what the problem can be. I'm new to the forum and tried to search for a solution with no avail. Any suggestion on a solution is really appreciated.
maxwedge
08-13-2008, 07:49 PM
Welcome to AF, does the security lite stay on? Do you have 12v to the starter solenoid when the ign is in the start position?
Hiway
08-13-2008, 08:58 PM
No security light. When I turn the IGN, only light on would be the SES light. I don't know if I'm getting 12v to the starter, how would I check it? I just tried to start it again, and it just fired up, like nothing was wrong. I'm gonna take it to a shop & let them run a diagnostics on it to see what went wrong. I'll post the result here for anyone that has the same issues.
Hiway
08-14-2008, 06:27 PM
The starter had a bad spot on it and need to be replaced.
