transmission fluid
level1stealth
07-24-2008, 11:14 PM
what kind of transmission and tranfer fluid should i use??? i have a 04 acura mdx..
H23A1Lude
07-25-2008, 02:08 PM
Go to your local Honda dealer and buy their ATF/MTF.
somick
07-28-2008, 11:04 AM
It has been discussed many times that if you use non Honda ATF you may experience shifting problems. So unfortunately you have to give some $$$ to Honda.
And while you are there you will probably want to buy VTM4 fluid for the rear differential. In my son's 04 Pilot it takes 3 quarts to replace it. It is a very easy procedure.
Good luck,
Sam
Good luck,
Sam
