Washer Fluid Not Being Pumped
lincolnmaster80
07-14-2008, 09:51 PM
Have a bit of a problem, got me a 1993 Bronco (full size) 351w, and when i go to spray some washer fluid, the wipers wipe but no washer fluid is sprayed. I've checked fuses and consulted my haynes manual, but no conclusions.
Anyone have any thoughts?
rhandwor
07-15-2008, 07:39 AM
Start by pulling a hose that goes from the pump to the next splice. Check if it sprays fluid. It might be plugged. If no fluid disconnect the electrical connection to the pump if you have power I would replace the pump. They usually are in the bottom of the fluid tank. You need to know if its a pump motor or wiring problem.
