removing fuel lines
wobbles1
07-14-2008, 09:18 PM
GA_googleFillSlot("Forums_ROS_300x250_noad");var tcdacmd="sa=a;sz=3;ad";
hi my name is ryan i bought a 95 chevy blazer 4.3L vortec with CMFI vinW. and within a week i had a collant leak (radiator hoes and thermostat blew at the time i thought my head gasket had blown but it hadent and a bolt broke in the thermostat housing and me and a friend tried to drill it out. my friend messed up the drilling and now i need to replace my upper intake manifold. otherwise i wil have a serious vacum leak. so im working on replacing the upper manifold i removed all the bolts but i cant figure out how i remove the fuel lines coming into the intake itsef. ive already removed the fuel injectors and obveusly the disrubtor is out too. if anyone ca help that would be really appreciated thank you.
sincerly
ryan
Scrapper
07-14-2008, 09:35 PM
it would be easier if you got a haynes manual for your blazer.if you don't want to do that have them print it out..autozone will do that or they'll show you it on screen...good luck..
scrapper1
MT-2500
07-15-2008, 08:04 AM
Does the fuel lines go into the back of it?
If so they will unbolt from the rear.
MT
