Need advice
bennyvilla21m
03-09-2003, 10:41 PM
i got a 91 Integra, i took out the B16A (origional) and put in a B16a Vtec, just because the bearings spun on the damn thing, Anyways i want to Rebuild the B18A and throw the B16a Head on the B18a, but in the future i want to throw in a turbo, what should i boost if i am going to do this? dont wanna have too much compression..
GSR
03-10-2003, 01:47 PM
there were no b16's offered in the states for integras
its not as easy as "throw the b16a head" on there...there are certain steps you must take to have a reliable ls-vtec/frankeistain converson. tap/plug oil source, bore 14mm dowel pins/bushigs on head, block girdle, oil squiters to name a few =)
you can boost to 250hp safely (psi needed to achieve this will differ from diff. sized turbos) on a tuned set-up...maybe more. cr isnt a problem, the ls's 6800 redline is
THE4TH
03-10-2003, 01:50 PM
yeah no sh*t, have fun with that one..
but you can boost it all to hell if it's tough enough
