Using 2 throttle bodys?
ABigWeaney
07-07-2008, 10:41 PM
This might be a dumb question, but i could not find anything about it. I was wondering if it would work to have 2 throttle bodys on a custom made smim to work in a dsm?
david-b
07-07-2008, 10:55 PM
Only way to have 2 would be to have 2 intake manifolds. 1 IM per 2 runners. Pointless on our motors I believe.
ABigWeaney
07-07-2008, 11:18 PM
would it hurt performance? or be a gain?
I am looking for a way to not have the big stock intake and have somthing that looks cool, and different but not hurt performance any.
vanilla gorilla
07-07-2008, 11:30 PM
If you got a Non turbo car you could run individual throttle bodies. One per cylinder. You'd be rockin like da honda kats.
ABigWeaney
07-07-2008, 11:37 PM
Its turbo, I seen that on a honda and it gave me the idea.
Thor06
07-08-2008, 04:28 PM
Why would you want to do it in the first place? Sounds like an aweful lot of work and I cant see any reason it would help.
TDIBABY
07-08-2008, 06:30 PM
if you want to get rid of the big stock intake stuff you could look into a MAF-T setup .. it will get rid of all that bulky factory stuff..allow you to vent into the atmostphere without any side effects... and you could use it to accomodate for larger injectors and some tuning if your not already using soemthing else..
SilvrEclipse
07-08-2008, 06:32 PM
I believe the 4g63 motor can get like a 75mm TB. Thats plenty big enough for anything you would be running.
TDIBABY
07-08-2008, 07:25 PM
you can also use a 90mm throtle body from a 90 year model infinity q45..might have to open up the opening on the intake manifold though...
Thor06
07-08-2008, 07:45 PM
Unless you are running a SMIM a new TB is pretty much wasted effort IMO, and once you need to upgrade a 75mm should be more than enough to do the trick. Also, the MAFT is nightmare to tune around, after reading some of the things I have I would never run one. DSMlink V3 will have speed density controls so if/when I push the limits on the 2g MAF I will just switch to speed density.
Killa
07-08-2008, 10:57 PM
hell I got mustang gt TB some where around here, It can be mod to fix the 4g63, mabe for the 420a too ? pm me :naughty:
heyyo302
07-17-2008, 09:19 AM
If you use 90mm throttle body (TB) opening on th intake manifold then can use but be caution it might be safe to drive it but you will probably experience a decrease in gas mileage and lowered performance. The fuel injectors are quite a ways from the tb. If anything is damaged, it may be the throttle body position sensor, check and replace that first, if you use 2 TB.
LandoAWD
07-17-2008, 10:21 AM
Pointless.
Also, the MAFT is nightmare to tune around, after reading some of the things I have I would never run one. It is tricky, but I'm getting there. :p
FWIW, this car was sold to me with the MAFT and pulled like a TRAIN. Once you dial it in (done by previous owner coding in hex with an EEPROM) issues are few and far between.
Thor06
07-17-2008, 04:35 PM
Really? I had heard that people would continue to calibrate and recalibrate the GM MAF all the time.
LandoAWD
07-18-2008, 08:34 AM
Really? I had heard that people would continue to calibrate and recalibrate the GM MAF all the time.Never had an issue till I went Link.
