92 cutless 3.3L rough idle when driving
dddaaa
06-30-2008, 11:33 PM
Does the "service engine" lite come on when the crank postion sensor is off a little? It was replaced recently and ran great for a while but now when the car is in gear and going down road, the car runs rough (The "service engine soon" lit is NOT on).
maxwedge
07-01-2008, 02:52 PM
on a 92 no cel for the CPS.
dddaaa
07-02-2008, 04:42 AM
Not sure what you mean by "no cel"? Also, could this be the problem (crank position sensor not quite aligned right?)
maxwedge
07-02-2008, 03:17 PM
CEL, check engine lite. Get off the CPS, rough could be anykind of misfire, very hard to determine the cause of a vague description such as this.
dddaaa
07-03-2008, 03:43 AM
So could be coil pack, spark plug wires, or clogged injectors?
maxwedge
07-03-2008, 02:37 PM
If it is a misfire, yes.
dddaaa
07-06-2008, 10:04 PM
How do I check the spark plug wires?
How do I check the coil packs using a voltmeter?
maxwedge
07-07-2008, 08:37 AM
Go to autozone.com, repair guides, plenty of info there regarding checking the plug wire and coils.
