1990 Chev truck K2500 4x4
Debschrysler
06-24-2008, 04:36 PM
I have a 1990 Chev Pickup truck with a 350. the speedometer does not work. there is no power at the plug and I have checked all the fuses. Does someone have a wiring scheme for this truck or any ideas what it could be. also the speed sensor on the transfer case has been changed.
You could email me at laforet@sympatico.ca with any help.:crying:
2000CAYukon
06-24-2008, 05:43 PM
Did the problem happen before or after the speed sensor was replaced?
No power at which plug?
//2000CAYukon
rhandwor
06-24-2008, 06:43 PM
I've found on older trucks that some people grab the wires and pull hard to disconnect them. Check all wiring plugs as you trace your wiring problem.
1968 Pontiac
06-24-2008, 09:28 PM
Could it be the VSS buffer?
