Air Bag dash light
chefjohn1
06-19-2008, 12:14 PM
Whet thru a deep puddle, light came on. Do I need to take it to a shop, or can I clear the light.
keithv35hp
06-19-2008, 03:47 PM
Mine came on and it took about a week, then it went off.
Keith:2cents:
chefjohn1
06-20-2008, 07:43 AM
Whent thru the puddle a year ago. I have had a piece of tape over it.
way2old
06-20-2008, 10:06 AM
You need a high end scan tool to read the code. Without having a code to research, it is close to impossible to guess at a fix. If you went through deep water, the problem is probably in the wiring.
chefjohn1
06-20-2008, 10:21 AM
Do you think that it could be the wiring on the front sensor. Should I take out the wire and clean it?
way2old
06-20-2008, 06:07 PM
The most likely spot is the mounting surface of the sensors. If you remove the sensor and clean the metal mounting(sensor and body), you might cure the problem. Good luck.
