91 PA Crank Position Sensor gap
Cam7
06-01-2008, 02:41 AM
Iam replacing a crank sensor on a 91 Pa 3800. My reference manual says that to adjust the Gap it requires a special tool. Can this be set with feeler gauges or is this a new tool item?
maxwedge
06-01-2008, 09:40 AM
Good info on this at autozone.com, repair guides.
HotZ28
06-01-2008, 10:30 AM
The FSM & AZ site (http://www.autozone.com/az/cds/en_us/0900823d/80/15/e4/2d/0900823d8015e42d/repairInfoPages.htm), recommends using the crankshaft sensor installation tool J 37089 or equivalent. Click Here (http://www.toolsource.com/crankshaft-sensor-adjustment-balancer-checker-p-95542.html?osCsid=61tcv6qkf4n0ilfo424vke1bd4) for a view & price. Obviously, this tool is too expensive for the DIY job. Click Here (http://www.automotiveforums.com/vbulletin/showthread.php?t=618623) for an alternate "rubber band" method. Be sure to check the interrupter rings for any bent tabs or other damage. Good Luck! :wink:
Cam7
06-03-2008, 04:27 AM
Thanks for the Info, never would have figured that one. Have done the Paper gap with ABS sensors and it works. Learn something New every once in a while.
