o2 simulators help!
95DodgeAvenger95
05-29-2008, 02:51 PM
i am trying to put my simultors in and i cant figure out what wires are the +12v, ground, and signal wire. i have a 96 3k the 4 wires on the o2's are 2 black and one blue and one white.
Crackhedbob341
05-29-2008, 07:36 PM
Funny you should ask, I just did a write up Tuesday on florida3s.
http://florida3s.com/forum/showthread.php?t=11481
95DodgeAvenger95
05-29-2008, 10:10 PM
thanks if i have any more questions ill let u know. thanks again.
95DodgeAvenger95
06-01-2008, 04:09 PM
well i did the simulators and im still getting a cel... what da eff
new2mitsu
06-02-2008, 12:50 AM
did you check for trouble codes?
95DodgeAvenger95
06-02-2008, 01:58 PM
Yes, says o2 sensor bank 2 sensor 1 and o2 sensor bank 2 sensor 2. ik its the ones after the precats but i but the simulator in and they still come on. i even tried to delete the codes from the ecu, worked for a few mins then they came back on. im almost positive i have it hooked up rite. im gonna get back under the car tommrow or wed to check how i have it set up bc i forget lol.
Crackhedbob341
06-02-2008, 03:49 PM
Check to see if the LED is blinking. Put the keys "ON" and look at the yellow box. If not then you have a power source problem. If it blinks then either you didn't do the blue signal right, or you must have 4 O2 sensors and you need the 2 white wires from the simulator for the 2 post cat sensors.... hopefully if that is the case you didn't get the 1 white wire version or one bank will see an error because only 1 bank is getting simulated, which is what it sounds like.
95DodgeAvenger95
06-02-2008, 08:38 PM
i got the dual simulator so it must be a power sorce prob bc im pretty sure i got the signal wire rite, ill check tommrow for the power
