gauge cluster
speeddevil
05-21-2008, 07:31 AM
i have an 02 trailblazer, my gauge cluster is completely gone dead nothing lights up what would cause it a simple fuse? is so where is it located at?
MT-2500
05-21-2008, 08:30 AM
Right side of dash with door open look for a plastic pull out door on end of dash.
And look for Under hood fuse box in engine compartment .
Also relay block and may be few fuses and relays right side under dash next to body pcm or behind glove box.
Take a test light and check for 12 volt power on both sides of fuse.
Some key on for 12 volts.
maxwedge
05-21-2008, 02:24 PM
The main fuse box is under the l/r seat. Check the grounds on the l/s of the engine block also. Hi MT2500, how have you been.
MT-2500
05-21-2008, 09:12 PM
Hello Maxwedge.
I am Still going.
Thanks for the info and good catch on fuses location.
I must have read old Mitch wrong.
Went back and looked and it said main fuse block under seat.
MT
I am Still going.
MT
speeddevil
05-23-2008, 07:22 AM
i have no idea every dang fuse and relay are working properly. the good thing is that its working properly. probably had a fuse out of location and when i checked them with my meter probably popped it in to place cuz they cluster is working properly.
TBer04
08-21-2008, 08:09 PM
I have an 2004 Trailblazer and having a problem with the gages and instrumeny cluster. The gas, oil press, water temp, and battery gages all show zero. The digital gear readout doesn't display what gear I'm in. The parking brake, ABS, air bag, and battery lights are on. The speedometer, tachometer, and odometer work great. Checked fuses and they are all good. What could be the problem?? Any help would be appreciated.
maxwedge
08-22-2008, 06:55 AM
Welcome to AF, this could be a bad connection at the cluster ground or at the head it self, also a bad ign switch can cause this, you will need some comprehensive diagnosis with this.
Khill
08-27-2008, 11:50 AM
not to join in late on a thread or whatever but...
i found this a while ago on ebay searching spare parts for my tb, if the problem is the cluster and not the connectors to it then you can buy one on ebay. The link is here (http://cgi.ebay.com/ebaymotors/_Car-Truck-Parts-Accessories__REBUILT-02-03-04-05-06-07-CHEVY-TRAILBLAZER-SS-CLUSTER_W0QQitemZ280259980746QQadnZCarQ20Q26Q20Tru ckQ20PartsQ20Q26Q20AccessoriesQQadiZ2865QQcmdZView Item?hash=item280259980746&_trkparms=39%3A1%7C65%3A1%7C240%3A1318&_trksid=p4506.c0.m245) and they will cross ship a rebuilt one for an old one for about 200 dollars, you can also get a different style of cluster if you want, they have all four. or you can always search elsewhere on ebay because other people are selling them too, but as spare parts, not exchange/repair.
just my :2cents:
just my :2cents:
maxwedge
08-27-2008, 04:13 PM
Good info, never too much stuff for our TB's, troublesome as they are. Just had the wiper recall done, the motor had to be replaced!
speeddevil
09-02-2008, 12:38 PM
is there such a website where one can check if there are any recalls for our vehicles?
MT-2500
09-02-2008, 01:57 PM
The dealer can run your vin no for recalls and TSB's.
AZ web site has some recalls and tsb's but are short on details.
The all data online repair info sub keeps you updated on all recalls and TSB's.
http://www.alldata.com/products/diy/index.html
