Emergency Fix on '93 Delta - Releasing Tensioner
jzack
05-17-2008, 09:25 PM
Son's girlfriend has an overheated car in our driveway. It's a '93 Olds Delta, Vin L type Engine, 3.8L V6 (3800 Tuned Port). A short hose just under the alternator is leaking badly. I'd like to repair on Sunday (tomorrow).
How is the serpentine belt tensioner released? 19mm socket to the pulley bolt or is there a hidden place to insert a socket extension (3/8 square bit) to release the tensioner? Here's a picture, wondering if the hole up at the 11 o'clock position is part of the release?:
http://www.streetneeds.com/uploads/auser/DSC02292.JPG
Looks like an easy repair -- undo the belt, unbolt the alternator and replace the hose underneath.
Any help/advice is appreciated?
Thx
BNaylor
05-18-2008, 09:50 AM
Since you do not have PM or email messaging active I am issuing this in thread warning. Please do not make multiple posts at various AF forums on the same issue and follow proper forum etiquette. Refer to our Community Guidelines. Your 4 other posts have been removed from the respective forums and from public viewing. I will allow the one posted here at Olds 88.
BE COURTEOUS: AVOID DUPLICATE POSTS
Do not post the same discussion more than once on a discussion forum or on many forums. Duplicate discussions can be frustrating for other members, especially for those whose time and energy is limited. Weeding through the same discussion in multiple locations can be not only frustrating, but down right annoying. Duplicate discussions will be deleted. Reposting the same message repeatedly can be interpreted as SPAM and could result in the loss of your membership. Also be conscious of your fellow members and avoid making meaningless posts for the sole purpose of increasing your post count.
HotZ28
05-18-2008, 10:01 AM
All you have to do is put a socket & pull-bar on the pulley bolt and lift it until you can remove the belt. Are you sure the hose is leaking under the alternator, or is the plastic hose fitting cracked? Click Here (http://www.automotiveforums.com/vbulletin/showthread.php?t=764169)for more info on that subject.
In addition to the items mentioned by Bnaylor above, your pic is too large! Try reducing the size to no more than 600X800 pixel before posting in the forums. Thanks to BNaylor for putting this thread in the proper section!
:iceslolan
jzack
05-18-2008, 11:19 AM
Thx guys - sorry for the mult-posts (didn't realize this large web site was that moderated - won't do again).
The hose appears to be leaking right in the middle betweent the two fittings. It's possible once I get it apart I'll find the barb is busted too?
HotZ28
05-19-2008, 09:17 PM
(didn't realize this large web site was that moderated - won't do again). Moderators on AF are few and far between, however, at this particular time of the year, we are expecting our annual increase and 2nd quarter bonus, so therefore, we are all more motivated! :rofl:
