95 blazer front end and interior
jrdavis87
05-17-2008, 02:41 PM
Can I put a '99 Blazer front end (headlights and grill) on a '95 Blazer??????
And can I put a '99 Dash in a 95
eddie1984
05-18-2008, 03:10 PM
i know u can put the front end on it but i dont know about the dash
ZL1power69
05-19-2008, 10:50 PM
Welcome to the site. Yes, both can be done. Swapping the front end parts isn't to difficult. You need the lights, grill, radiator core support, headlight pigtails, and misc mounting hardware and clips from a 98+ s-series truck. Grills from most base models are flat black and some grills on 00+ trucks (xtreme, zr2, lt) are body colored. I'm not sure what the part list would be for swapping the dash besides the dash and all associated components from a 98+ truck but I know the swap can be very time consuming and expensive. Also plan on swapping out the heater core while your at it. You have to deside if the time and money involved in these swaps is worth it to you. If your 95 has high mileage or is well worn, then these two swaps might cost half of your truck's value. Again its up to you though.
jrdavis87
05-20-2008, 05:23 PM
Thanks!!! When you put it that way it sounds like to much work to do....
