Where To Add Refrigerant Oil?
IsuzuGal
05-11-2008, 05:15 PM
Where do I put the refrigerant oil in the receiver/dryer for a 2001 Isuzu Rodeo LS 2.2? On the top of my receiver/dryer there is an "In"...is this where I am suppose to add it? I just want to make sure I put it in the right spot.
Thank you,
Gina
Thank you,
Gina
Will Help
05-11-2008, 05:35 PM
Typically the oil charge goes into the inlet ( unless you have the system open and then you pour it directly into the system). Are you just useing an oil charge can ( small can ) or are you useing a referigerant with oil supplement added. Just be sure if you are adding refrigerant with oil supplement that you do not over charge the system.
IsuzuGal
05-11-2008, 08:23 PM
Thank you so much. I am actually installing a new receiver/dryer. Thanks for all the info.
