97 Grand Voyager won't start
Harlow727
05-10-2008, 02:57 PM
Replaced starter yesterday, wouldn't start. Replaced both battery cables, started and ran yesterday evening. This morning it won't start. Rechecked cables, relay is clicking, fuses are fine. HELP!!
tempfixit
05-10-2008, 03:15 PM
Can't remember for sure but there should be another relay in the PDC you can switch with to see if the relay is the problem. Worth a try.
Good Luck
Good Luck
Harlow727
05-10-2008, 03:47 PM
Switched relays, checked fuses, still no start. Something behind the glovebox on the passenger side is cycling when you turn the key. I do not recall it ever doing it before.
Harlow727
05-13-2008, 02:15 AM
Shop found the problem, aftermarket ignition kill switch that had been deactivated before we got the van somehow came back to life. Apparently it had a short and was disarmed a long time ago, but not properly. When it was triggered to come back on, since it originally had a short, it would sometimes start and sometimes not. They removed it for me :)
tempfixit
05-13-2008, 08:26 PM
Glad to see your going again. Great the fix took care of all three of your post problems.
