AIR DRIED BEEF DOG FOOD
1991 honda civic amp install
cfrank2
05-09-2008, 12:38 PM
Im helping a friend install a pioneer amp that came with his 1991 honda civic and i was wondering where the best place to draw power would be? I would really like to just tie it into the ignition that way i dont have to worry about it draining the battery. Not really familiar with hondas so if anyone has wiring diagrams or any advice i would appreciate it. The way it is hooked up now is it is just drawing power directly from the battery.
Thanks
pre98zetec
05-09-2008, 01:47 PM
right to the battery. Make sure you have the correct amperage in-line fuse connected to the wire before the amplifier.
PaulD
05-09-2008, 03:40 PM
the main power comes from a wire directly attached to the battery, there is also a small turn-on wire that comes from the head unit that acts as a switch to turn the amp on when the head unit turns on.
vanilla gorilla
05-11-2008, 01:13 AM
Yeah the power comes directly from the battery. And yes like stated previously you will need a in line fuse after the battery. You will have to get the right amperage fuse also depending on what size wire you got.
pickering_autoshop
05-12-2008, 10:38 AM
yo can always install a switch so u can turn it on manually. I did that on my one friends car. all you have to do is had a power wire with a fuse on it heading to one part of the switch, and the amp's power coming from the other part of the switch
pre98zetec
05-12-2008, 11:59 AM
if you want to install a power switch its not safe to install it on the power wire, install it on the remote wire... Most headunits have a sub on/off so installing a switch is a waste of time
PaulD
05-12-2008, 07:57 PM
agreed, you wouldn't want a switch carrying that kind of current
pickering_autoshop
05-13-2008, 10:22 AM
it really is safer than you think it would be. the owner of the car i had installed it on is a automotive technician/Mechanic, and it was his idea to install it. So he would know if it was safe or not. ad of course there would be a fuse on the power wire.
pre98zetec
05-13-2008, 11:40 AM
unless its a very heavy duty switch that can handle alot of amps then it's not safe.
pickering_autoshop
05-14-2008, 11:59 AM
no crap
pre98zetec
05-14-2008, 04:08 PM
so lets see this high amperage switch....
junshun
05-16-2008, 12:55 AM
I suppose we do not know whether is safe or not,i have an advice ,you can find some information in
link removed - spam
it may do your some favor.
